Struggling with my Jowihue upgrade from HS3 to HS4.
Getting the following errors :
- Error running event action: Feature with reference 482 does not exist (there is no object 482)
- Error: (UpdateGroups):Object reference not set to an instance of an object.
- Unexpected reply indicating bridge Philips HUE 1 is beeing overloaded with commands
- Error: (SetDeviceByUserRequest):SDBUR setstate sat start-----Object reference not set to an instance of an object.
- Error: (UpdateGroups):Column 'bridgeserial, id' is constrained to be unique. Value is already present.
Deleted all objects, re-installed Jowihue to re-create everything.
Scenes take a very long time 15+ minutes to run (if ever).
Can't seem to find anything in the logs either.
FYI running 2 bridges with about 48 objects on HUB1 / 21 objects on the HUB2. Running the very latest plugin & HS4 version (non-beta)
Starting to wonder if I have some database corruption somewhere.... Anyone with suggestions ?
Phil
Phil
