I am having issues adjusting colour temp/sat as well as some other features created for some Hue bulbs, the logs report "Object reference not set to an instance of an object"
Can you suggest where I need to look to get more information or steps I can take to resolve the errors?
08:58:57.0025400 -- (HSPI.SetIOMulti) triggering by user request: 2022-01-11 8:58:57 AM ref:2558 value:32729 Type:7 string:
08:58:57.0157490 -- (JowiHueUtils.SetDeviceByUserRequest) Debug: SetDeviceByUserRequest:Start ref=2558 Action:32729 controltype:7 Controlstring:
08:58:57.0256090 -- (BridgeApi.SetLights) Set lights starting
08:58:57.0263430 -- (JowiHueUtils.SetDeviceByUserRequest) Error: HWQ: dequeue command:SDBUR setstate hue start-----Object reference not set to an instance of an object
08:58:57.0318830 -- (JowiHueUtils.SetDeviceByUserRequest) System.NullReferenceException(0x80004003): Object reference not set to an instance of an object
at HSPI_JowiHue.BridgeApi.SetLights (System.Boolean IsLight, HSPI_JowiHue.Creativity.IDKey IDKey, System.Nullable`1[T] Lon, System.Nullable`1[T] Transition, System.Nullable`1[T] Bri, System.Nullable`1[T] Hue, System.Nullable`1[T] Sat, System.Nullable`1[T] ct, System.String Alert, System.String Effect, System.Nullable`1[T] Speed, System.Nullable`1[T] FanSpeed, System.Nullable`1[T] Lift) [0x0010d] in <0502350a77554578905b2332fe47803e>:0
at HSPI_JowiHue.JowiHueUtils.SetDeviceByUserRequest (System.Int32 Ref, System.Int32 Action, HomeSeer.PluginSdk.Devices.Controls.EControlType controltype, System.String ControlString) [0x011f3] in <0502350a77554578905b2332fe47803e>:0
08:58:57.0324870 -- (JowiHueUtils.SetDeviceByUserRequest) Debug: :End
08:58:54.3404080 -- (MyBridgeScenes.InitialBridgeScenes) Debug: starting for 'Philips hue'
08:58:56.8903850 -- (BridgeApi.SendRequest) sendrequest total took 108
HS4 4.2.7.0 Linux on Ubuntu 20.04
JowiHue 4.0.6.0
deCONZ 2.13.04
ConBee II 0x26700700
JowiHue 4.0.6.0
deCONZ 2.13.04
