No Gateway Found
    No Gateway Found
    Hi! I'm hoping someone may be able to point me in the right direction. I've had homeseer+jowihue+conbee2 all connected before. I've gone through a move and have just gotten back around to setting everything back up. When I updated to the latest version of HS4, Phoscon was no longer making a connection. I deleted everything and reinstalled, reset all the lights and now they're all connected back to Phoscon. However, now I'm running into the issue that JowiHue is not able to detect a gateway. It was able to detect my hue bridge.
    Any advice would be greatly appreciated!
    If you go to this site with a browser on the machine where you have the plugin running, does that link show you the IP address where deCONZ?
    If it does not show anything, there is an issue with the network configuration of the PC (UPNP settings).
    Another possibility is that the plugin did not get the network access it needs to function when you run it on a Windows machine. Did you confirm the popup when the plugin first started? It needs to be allowed access to the network through the firewall. The easiest way to check this is to disable the firewall temporary and then start the plugin. if it finds the bridge in this case, you need to add the plugin to the firewall rules to allw acces to the network.
    Wim
    -- Wim
