Hi Wim,
I am using two Phillips Hue Hubs both running current firmware and I am seeing a difference between the Groups "Features" when the devices are generated between the two hubs.
The first hub, Downstairs, has the full feature set whereby the second hub, Upstairs, is not and only has On/Off/Dim and this is for all Groups in the second hub. I have deleted and recreated devices but this results on the same outcome. The only distinction I can find is the first device in the Downstairs is a floured light and in Upstairs, this is a white light. Can you please advise where to look next as I can establish why this is the case.
Thanks in advance
Tim
Thanks in advance
Tim
