ZG-003 Zigbee Relay
    ZG-003 Zigbee Relay
    Just as a confirmation for anyone that's looking for a Zigbee controlled relay, these seem to work
    https://www.aliexpress.com/item/1005003020806446.html
    https://www.aliexpress.com/item/1005003671178960.html
    These are both basically the same, the difference being that the 2nd one comes mounted in a case - the boards inside are exactly the same. They appear in HS as 4 on/off switches.
    Click image for larger version  Name:	Capture.PNG Views:	0 Size:	86.7 KB ID:	1524775
    I bought one with the case and one without.
    You probably will need to play with the mode switch. By default it comes set to only allow one of the 4 relays to be on at once. When you turn on the 2nd one, the 1st one will turn off. Pressing the mode button will change it so that when you set it on, the relay comes on, then goes off again after about a second (I don't know if you can change that timing), so it's basically a momentary push button. The next mode allows you to turn the 4 relays off/on independently, so you can have all 4 on at the same time if you want.
    Not really sure how I'm going to use them in production, I just wanted something to test and play with.
    G
    That's a good find!
    You can use them with sprinklers or the outside garden lights...etc
    Eman.
      Thanks for this information - will find a use for one of these.
