Errors after upgrading from 4.0.6.0 to 4.0.6.2
    Hello.
    I just upgraded to 4.0.6.2 (HS4 4.2.7.0) and see some errors when starting up HS4.
    Starting up....
    09.02.2022 08:36:13 JowiHue~!~Info~!~Error: The 'SensorTypes' start tag on line 1183 position 2 does not match the end tag of 'SensorType'. Line 1362, position 5.
    09.02.2022 08:36:15 JowiHue~!~Info~!~Error: The 'SensorTypes' start tag on line 1183 position 2 does not match the end tag of 'SensorType'. Line 1362, position 5.Startup Complete, 2 errors detected, check the log for more information.
    This errors was not present with v4.0.6.0.
    Any suggestion/explanations?
    Thanks!
    Cheers from Norway,
    Ole
    I guess I have posted the solution in the other thread you posted in? If not let me know?
    -- Wim
      Thanks!
      Case closed.
        Same issue here:
        How can this be solved?
        Edit: Found it!
