I had deCONZ and the JowiHue plugin working with my new Hometroller Pro with two test devices, and when I changed my Hometroller Pro IP address, plugin was not able to see Phoscon-GW. I deleted the gateway from plugin and then tried to login into the Phoscon app to start process of adding gateway again. When I tried to login to Phoscon, it prompted "A new login password must be set to increase security".
After some attempts to get past this, I did an uninstall and then installed deCONZ ver 2.14.01 dated 2/7/22. On first login to Phoscon I can set password and get to the point of allowing 3rd party apps to connect, but the plugin does not connect, and the HS log has the following:
JowiHue
Info
UPNP-backdoor no valid response from IP in INI file, Please check IP seems to be bridge, but not a correct response (is bridge updated to latest level?)
BTW, after first login to Phoscon, all additional attempts to login fail with "Login Failed". I did notice that by deleting the password file, I can set pw and login in, but any additional login attempts fail.
I'm I using a version of deCONZ that is not fully vetted with this plugin?
JowiHue
Info
