Log
Getting an error in logs since last update
That is me getting old and repeating things... I copied a wrong file in the distribution. Download the file in this thread and follow the steps... sorry!-- Wim
Yuch.... but at least the frequency went down LOL
Will be gone in the next release-- Wim
- Likes 1
I just installed ver 4.0.6.3 and have the error as well, but also see some other errors. I'm starting deCONZ before I start HS4, but plugin indicates Phoscon-GW is Not reachable. Should I be seeing that message? The log is also indicating that a file is missing...
Here is the log:
2/26/2022 1:15:56 PM JowiHue Info Refresh bridge Phoscon-GW set to 90 seconds after establishing direct connection
2/26/2022 1:15:56 PM JowiHue Info socket opened for Phoscon-GW on 10.50.1.15:443
2/26/2022 1:15:50 PM JowiHue Info Error: The 'SensorTypes' start tag on line 1183 position 2 does not match the end tag of 'SensorType'. Line 1362, position 5.
2/26/2022 1:15:50 PM JowiHue Info Importing lampTypes
2/26/2022 1:15:50 PM JowiHue Info ============================================================ ==================================
2/26/2022 1:15:50 PM JowiHue Info -------------------------------------Plugin info ---------------------------------------------
2/26/2022 1:15:50 PM JowiHue Info 0 Animations available for use in this plugin
2/26/2022 1:15:50 PM JowiHue Info 0 Local scenes available for use in the JowiHue plugin
2/26/2022 1:15:50 PM JowiHue Info 30 Presets available for use in the JowiHue plugin
2/26/2022 1:15:50 PM JowiHue Info -------------------------------------Bridge info ---------------------------------------------
2/26/2022 1:15:50 PM JowiHue Info 0 Alarmsystems available on bridge 'Phoscon-GW'
2/26/2022 1:15:50 PM JowiHue Info 1 Humidity sensor(s) found on bridge 'Phoscon-GW' with 1 supporting HS device(s)
2/26/2022 1:15:50 PM JowiHue Info 1 Temperature sensor(s) found on bridge 'Phoscon-GW' with 1 supporting HS device(s)
2/26/2022 1:15:50 PM JowiHue Info Using firmware level 0x26720700
2/26/2022 1:15:50 PM JowiHue Info Bridge Phoscon-GW is at version 2.14.1 of type deCONZ on a ConBee II
2/26/2022 1:15:50 PM JowiHue Info 0 Groups available on bridge 'Phoscon-GW'
2/26/2022 1:15:50 PM JowiHue Info 1 lights and/or plugs connected to bridge 'Phoscon-GW'
2/26/2022 1:15:50 PM JowiHue Info Started deCONZ bridge Phoscon-GW
2/26/2022 1:15:50 PM JowiHue Error Error: (MoveNext):Could not load file or assembly 'netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51' or one of its dependencies. The system cannot find the file specified.
2/26/2022 1:15:50 PM JowiHue Info * Bridge Phoscon-GW at 10.50.1.15:8080 not connected (not reachable). Did IP address change?
2/26/2022 1:15:50 PM JowiHue Warning Warning: Bridge Phoscon-GW Not reachable on 10.50.1.15 Is bridge powered on Or IP/Port address has changed?
2/26/2022 1:15:48 PM JowiHue Info Error: The 'SensorTypes' start tag on line 1183 position 2 does not match the end tag of 'SensorType'. Line 1362, position 5.
2/26/2022 1:15:48 PM JowiHue Info Importing lampTypes
2/26/2022 1:15:48 PM JowiHue Info settings loaded
2/26/2022 1:15:48 PM JowiHue Info Starting plugin JowiHue 4.0.6.3 On Windows
2/26/2022 1:15:48 PM JowiHue Info Logfile is set to C:\Program Files (x86)\HomeSeer HS4/Logs/JowiHue.log
Did you download the file from post #5? This should take care of the Sensortypes error.
The other error is not about the bridge, but about the netstandard assembly missing in the .NET environment. I guess you updated the plugin, skipping a few versions?
The challenge now is that you need to refresh the .NET installation as this will enable the netstandard assembly as well I believe. Best is to reinstall the .Net framework 8. Cannot get an English link here as I keep ending up at the dutch framework, but a search will point you to the correct location
Wim-- Wim
I updated plugin using the link showing there was an update. Do I need to install the .net framework 4.8 (Download .NET Framework 4.8 | Free official downloads (microsoft.com))? After I install it, is there anything else needed?
Thanks!
It should be all I expect. Normally even just a refresh of your current version is good as well-- Wim
.net 4.8 installed, hometroller pro rebooted.. loadfile issue looks to be corrected but SensorTypes error remained until I downloaded and placed in config folder.
Below is new log. Can you advise on how to correct the Phoscon not connected? It looks like it tries port 8080 before it is able to connect on 443:
2/26/2022 4:43:13 PM JowiHue Info FindBridges stap 1.1 meethue call
2/26/2022 4:43:09 PM JowiHue Info Refresh bridge Phoscon-GW set to 90 seconds after establishing direct connection
2/26/2022 4:43:09 PM JowiHue Info socket opened for Phoscon-GW on 10.50.1.15:443
2/26/2022 4:43:03 PM JowiHue Info -------------------------------------Bridge info ---------------------------------------------
2/26/2022 4:43:03 PM JowiHue Info ============================================================ ==================================
2/26/2022 4:43:03 PM JowiHue Info 30 Presets available for use in the JowiHue plugin
2/26/2022 4:43:03 PM JowiHue Info 0 Local scenes available for use in the JowiHue plugin
2/26/2022 4:43:03 PM JowiHue Info 0 Animations available for use in this plugin
2/26/2022 4:43:03 PM JowiHue Info -------------------------------------Plugin info ---------------------------------------------
2/26/2022 4:43:03 PM JowiHue Info 2 lights and/or plugs connected to bridge 'Phoscon-GW'
2/26/2022 4:43:03 PM JowiHue Info 0 Groups available on bridge 'Phoscon-GW'
2/26/2022 4:43:03 PM JowiHue Info Bridge Phoscon-GW is at version 2.14.1 of type deCONZ on a ConBee II
2/26/2022 4:43:03 PM JowiHue Info Using firmware level 0x26720700
2/26/2022 4:43:03 PM JowiHue Info 1 Temperature sensor(s) found on bridge 'Phoscon-GW' with 1 supporting HS device(s)
2/26/2022 4:43:03 PM JowiHue Info 1 Humidity sensor(s) found on bridge 'Phoscon-GW' with 1 supporting HS device(s)
2/26/2022 4:43:03 PM JowiHue Info 0 Alarmsystems available on bridge 'Phoscon-GW'
2/26/2022 4:43:02 PM JowiHue Info Started deCONZ bridge Phoscon-GW
2/26/2022 4:43:02 PM JowiHue Info * Bridge Phoscon-GW at 10.50.1.15:8080 not connected (not reachable). Did IP address change?
2/26/2022 4:43:02 PM JowiHue Warning Warning: Bridge Phoscon-GW Not reachable on 10.50.1.15 Is bridge powered on Or IP/Port address has changed?
2/26/2022 4:43:01 PM JowiHue Info Importing SensorModels
2/26/2022 4:43:01 PM JowiHue Info Importing SensorTypes
2/26/2022 4:43:01 PM JowiHue Info Importing lampTypes
2/26/2022 4:43:00 PM JowiHue Info Starting plugin JowiHue 4.0.6.3 On Windows
2/26/2022 4:43:00 PM JowiHue Info settings loaded
2/26/2022 4:43:00 PM JowiHue Info Logfile is set to C:\Program Files (x86)\HomeSeer HS4/Logs/JowiHue.log
I am still seeing the issue with the new update. Resolved by putting this file in Config https://forums.homeseer.com/forum/li...57#post1526357
Definitively solved in the latest release-- Wim
- Likes 2
