I keep getting this error. I've deleted the bridge, re added it, tried rebooting and I keep getting the error. I have two other Bridges and a Phoscon and they are running with no errors. Any ideas?
Warning: Bridge Not reachable.
Appending to this, as I have the same (possibly) problem. My logs are flooded with alternating "Can't find bridge" warnings, and a related error from JowiHue. I have tried:
- Restarting multiple times
- Updating JowiHue to latest, although that seems to be malfunctioning. I'm on 4.0.7.4, but .5 is available. Have tried installing this multiple times, but after getting a "plugin installed successfully" message from HS4, it still says 4.0.7.4 in the overview. Anyways...
- Physically unplugged the deConz stick
Screenshot of HS4 log
Snippet from verbose logging capturing, I believe, this exception (although from a different point in time):
Code:16:32:13.0810650 -- (VB$StateMachine_21_UpdateBridgeCache.MoveNext) Debug: starting cache tasks Phoscon-GW 16:32:13.0810650 -- (Mylights.InitialLights) starting for 'Phoscon-GW' 16:32:13.0821566 -- (Mylights.InitialLights) Base info light Configuration tool 1 1 updated 16:32:13.0824115 -- (Mylights.InitialLights) Base info light Range extender 2 2 updated 16:32:13.0826011 -- (VB$StateMachine_9_TriggerCheckHandler.MoveNext) start deconz update sensors 7 - 8 16:32:13.0830924 -- (MySensors.UpdateSensors) update sensors is starting 16:32:13.2729477 -- (VB$StateMachine_21_UpdateBridgeCache.MoveNext) Error: HWQ: dequeue command:bridgeupdate cache Phoscon-GW check 15 Objektreferanse er ikke satt til en objektforekomst. 16:32:13.2759712 -- (VB$StateMachine_21_UpdateBridgeCache.MoveNext) System.NullReferenceException(0x80004003): Objektreferanse er ikke satt til en objektforekomst. ved HSPI_JowiHue.DeCONZCache.VB$StateMachine_21_UpdateBridgeCach e.MoveNext() 16:32:13.2761442 -- (VB$StateMachine_21_UpdateBridgeCache.MoveNext) Ending deCONZ cacheupdate for Phoscon-GW update running: False 16:32:13.2761442 -- (VB$StateMachine_21_UpdateBridgeCache.MoveNext) exit; Update running =False
System details:
HS4 (latest) on Windows 10
Are you running a Conbee or Conbee II? I was seeing errors when using these USB devices. Finally I just used a RPI I had laying around and put a Raspbee II hat on it (I'm running two now). Since I got around the USB stuff I have only had an error once on one of my RPI's. All I did was VNC into the RPI and rebooted the device, all was good.
Originally posted by Bigstevep View PostAre you running a Conbee or Conbee II? I was seeing errors when using these USB devices. Finally I just used a RPI I had laying around and put a Raspbee II hat on it (I'm running two now). Since I got around the USB stuff I have only had an error once on one of my RPI's. All I did was VNC into the RPI and rebooted the device, all was good.
Also, I realize now I should probably have made a new thread rather than hijacking yours - we may not have the same problem. I figured this could be a widespread thing, seeing your symptoms. But if you are on an RPI, that makes it fairly different I assume.
Originally posted by kenm View PostFor the USB device driver, are you using the Microsoft USB driver or the deCONZ driver? For Windows 10, the Conbee II instructions say to use the driver that's automatically installed vs. installing the Windows 7 driver. I'm not sure if this has anything to do with it but worth a shot.
Great to see it got resolved. deCOnz is updating their version a lot. It is god to at least each 2 months or so for the latest stable version.-- Wim
