I just upgraded from HS3 to HS4. I didn't have JowiHue installed at the time I upgraded, so there was no need to migrate JowiHue devices from HS3 to HS4. After upgrading to HS4, I installed JowiHue version 4.0.7.6. I have a Philips Hue Bridge. I ran into two kinds of duplicate problems:
1. Duplicate devices (but features under the duplicated devices were not duplicated)
2. Devices that were not duplicates, but within a device, features were duplicated.
I have 35 Philips Hue lights, and about half of my devices fell into category Home or Forum above.
I actually documented this duplicate problem in detail in a thread that I wrote, but I mistakenly wrote that thread in the HS3 forum:
https://forums.homeseer.com/forum/li...wiehue-plug-in
I was hoping to move that thread from the HS3 forum to the HS4 forum, but wasn't possible. Anyway, it seems the HS3 forum isn't looked at much, so I figured I'd post a new thread here.
Anyway, I manually deleted duplicate devices as recommended in the Homeseer log. For devices that were not duplicated, but whose features were duplicated, I just removed the devices. After removing the devices, I restarted the plug-in. Then, some devices (or features) might get duplicated again. It took about 3 iterations of deletion/restart until I finally had no more duplicates. So, at least now, no more duplicates, and I did test that turning on or off devices in HomeSeer correctly turned on or off the actual devices. I haven't had time to test Hue, Sat, RGB, CT, but at least I know on/off for all devices work.
So, just wanted to point out that there is an issue with this version of the plug-in causing duplicates to be created.
