Originally posted by w.vuyk
View Post
9000 devices created because of an air quality sensor?
I have no issues here with the airquality device, and did not hear back with the latest versions of the plugin?
Was this ever resolved? Has the plug-in had any error-handling changes to prevent this from happening again?
Originally posted by w.vuyk View PostMost types should not cause problems. But one never can guess what new device will emerge, so I cannot promise on that
I deleted the device from DeConz when I first discovered the problem (two days later) and will not pair it again until the next plug-in version is available.
There are likely other kinds of unknown devices that could show up in the future, is there a way for the plug-in to not do the same thing again if/when that happens?
The script jon00 posted looks good for its goal indeed, but did not test it.
The issue here is that the HS3 plugin does not support the airquality device. Probably becuase it sees the temperature sensor, it tries to create the device anyway. I will send out an update on the plugin that excludes the airquality sensor, so it will not create the loop in devices anymore. My advise is to remove the device from deCONZ for now so the plugin will not try to create any devices for the sensor. Once the update is out, you can add the device again.
Wim
yeah, and I saw that, and replied about it's not working. so, uh, thanks?
and now I'm down the rabbit hole of refreshing my understanding of how hs handles devices. It would appear there are a few not-bogus devices in this range (which I only caught purely by accident) and I'd need to amend the script to check against the device name before deleting it.
I raised the question HERE because I'd like the plug-in developer to SEE it.
My question about handling devices and deleting them is of a more generic nature, but of a more pressing concern.
I've brought the corrupted database back online, and have found the 1st of the 7689 duplicate devices that got created.
I changed the 'room' on that 1st one from being 'not set' to an existing room. I then went back to the device list, and attempted to get them selected for deletion.
Chome was NOT having it:
Exception generating device utility page main view table (0): Exception of type 'System.OutOfMemoryException' was thrown.-> at System.Text.StringBuilder.ToString() at Scheduler.DeviceUtilityPageBuilder.GetStatusPage_MainContent (String UserName, clsViewSortStateData& VD)
Same with Firefox, and Opera.
So I switched to an instance of Edge running on a different machine (the one hosting HS3) Edge kept complaining about the page 'not responding'. After clicking [Wait] on that dialog a dozen times, I gave up.
Is there a way to programmatically delete a range of devices, from x deviceID to y deviceID?
Using HS3 with the 2.18 DeConz gateway (windows). I added an Aqara air quality sensor to the DeConz config a few days ago. This one: https://www.amazon.com/gp/product/B094R8RBWT
Just now I got an error on HS3 telling me there were more than 9000 devices, and everything had slowed to an absolute crawl.Too many devices, cannot create more than 9000 devices
I managed to get the device list to limit showing only things in the 'Not set' room. And in there I found 7689 devices related to that Air Quality device.
I checked the DeConz window and it was not showing anything out of the ordinary in the graph view.
For my sanity's sake, I immediately stopped DeConz and HS3. Backed up everything in the HS3 folders.
I restart DeConz and deleted the air quality device. I don't need it "right now" and would rather not have it freak out the HS3 database again.
I restarted HS3 and changed the database to one from a few days ago, and it safely showed my expected 1200+ devices. So I've got a fallback, though it's missing some events I'd spent some time configuring in the last week.
I have managed to slog back through the logs and I see when the problem started:Oct-22 11:14:45 PM JowiHue Issue occurred while creating sensor device, please notify plugin owner with the lines logged here Oct-22 11:14:45 PM JowiHue Error: (CreateNewDevice)::Error: Requested value 'ZHAAirQuality' was not found. Oct-22 11:14:45 PM JowiHue Creating device for AirQuality 43 of type ZHAAirQuality Oct-22 11:14:45 PM JowiHue Creating device for AirQuality 43 of type ZHAAirQuality Oct-22 11:14:00 PM JowiHue Device found supporting Air quality, plugin does not yet support this...get support on the forum for this? Oct-22 11:14:00 PM JowiHue sensor type ZHAAirQuality Oct-22 11:14:00 PM JowiHue tried to create device for sensor AirQuality 43
It seems to have been trying to do this repeatedly, ever 15 seconds, for the past four days. And in the process it ran amok creating devices in HS3.
Have you seen anything like this happen before? And were would you like me to start, debugging-wise?Tags: None
- Likes 1
