Found in DeConz but no device created
    Click image for larger version  Name:	Sans titre-4.png Views:	15 Size:	203.9 KB ID:	1576145 Hi all,
    Just got a cheepo temperature sensor from china ...
    It was detected in DeConz, but no devices where created in HS.
    Plugin was restarted, HS was restarted, system and Conbee2 was restarted, what more can I do ?
    Cheers
    What I've found is "detected" does not mean "supported" in DeConz. The "unknown" for Manufacturer and Model Identifier is a good indicator that it isn't supported. Only devices that are supported are made available to the REST API which is what Wim uses for his plugin. I stick with Aqara as they are well supported in DeConz.
      Look here before purchasing Zigbee devices to see if they are supported. httxx://zigbee.blakadder.com/deconz.html.
      I run both DeConz and zigbee2mqtt and there are some devices that can be seen in one or the other but if not supported by the controller then no data most likely.
        Can you get a value of the model from read the Basic Cluster? Maybe with the appropriate DDF file you can add it to deCONZ.
          Thank you all, I did not even know what a cluster was 10 minutes ago, I never had a look at DeCONZ.
          The model appears as:
          Manufacturer: _TZE200_znbl8dj5
          Model identifier: TS0601​
          and there are some other topics about it.... Guess I will have to practice in DeCONZ to have it set.
            Thanks to all, that was a cat-ham​mock detection project that ​went very​ fast, cheap and easy 😺
Name:	2022-11-18 10.22.15.jpg
Name:	2022-11-18 10.27.51.jpg
              Hahahaha great idea!
              Edit:
              Regard your issue, i found this in Github https://github.com/dresden-elektroni...in/issues/6063
              Maybe Ltek can help you more...but, if it was me, i'll try this DDF (just change manufacturename and modelid)
              "schema": "devcap1.schema.json",
              "manufacturername": "_TZE200_qoy0ekbd",
              "modelid": "TS0601",
              "vendor": "Tuya",
              "product": "Temperature and humidity sensor",
              "sleeper": true,
              "status": "Gold",
              "path": "/devices/tuya/_TZE200_qoy0ekbd_temp_hum_sensor.json",
              "subdevices": [
              "type": "$TYPE_TEMPERATURE_SENSOR",
              "restapi": "/sensors",
              "uuid": [
              "$address.ext",
              "0x01",
              "0x0402"
              "items": [
              "name": "attr/id"
              "name": "attr/lastannounced"
              "name": "attr/lastseen"
              "name": "attr/manufacturername"
              "name": "attr/modelid"
              "name": "attr/name"
              "name": "attr/swversion"
              "name": "attr/type"
              "name": "attr/uniqueid"
              "name": "config/battery",
              "awake": true,
              "parse": {
              "at": "0x0021",
              "cl": "0x0001",
              "ep": 1,
              "eval": "Item.val = Attr.val / 2;",
              "fn": "zcl"
              "default": 0
              "name": "config/offset",
              "default": 0
              "name": "config/on"
              "name": "config/reachable"
              "name": "state/lastupdated"
              "name": "state/temperature",
              "parse": {"fn": "tuya", "dpid": 1, "eval": "Item.val = 10 * Attr.val;" },
              "read": {"fn": "none"},
              "default": 0
              "type": "$TYPE_HUMIDITY_SENSOR",
              "uuid": [
              "$address.ext",
              "0x01",
              "0x0405"
              "items": [
              "name": "attr/id"
              "name": "attr/name"
              "name": "attr/type"
              "awake": true,
              "parse": {
              "at": "0x0021",
              "cl": "0x0001",
              "ep": 1,
              "fn": "zcl"
              "default": 0
              "default": 0
              "name": "config/on"
              "name": "state/humidity",
              "parse": {"fn": "tuya", "dpid": 2, "eval": "Item.val = 10 * Attr.val;" },
              "read": {"fn": "tuya"},
              "default": 0
              "bindings": [
              "bind": "unicast",
              "src.ep": 1,
              "cl": "0x0001",
              "report": [
              "at": "0x0021",
              "dt": "0x20",
              "min": 60,
              "max": 3600,
              "change": "0x00000001"
                Can I run deConz (howihue plugin) and zigbee2mqtt off of the same conbee II device or do I need separate paths to the zigbee network?
                  Thanks Nunoary, I found a suiting DDF for _TZE200_znbl8dj5 on Github, and it works great, after learning how it had to be set...
                    I never tried it so I don't know. You can use the DeConz dongle (or Raspi 2 GPIO hat) to run zigbee2mqtt but I use the SonOff dongle for my zigbee2mqtt devices. I use DeConz and the Jowihue plugin for all of my Hue devices and one Aqara FP1 sensor.
                      vasrc What a creative idea! hahaha But doe the cat not bother the bump in its but? LOL
                      Glad you got it working
                      -- Wim
                        Before going crazy, try restarting HS. It happens to me fairly often.
