I just moved from the Homeseer HS4 Zigbee Plugin to the JowiHue plugin with a Phoscon gateway. The issue I am having is the LEDVANCE BR30 RGBW is not showing up with color control.
It only has the following controls.
1. On/Off/Dim
2. Extra
3. CT
The RGB control does show up on the Phoscon App for these bulbs.
I also have several LEDVANCE A19 bulbs that are also RGBW and the color control shows up in the device on Homeseer HS4 with the JowiHue plugin.
Any suggestions or guidance would be greatly appreciated. Below is more detailed information.
HS4 Version: HS4 Pro Edition 4.2.16.0 (Windows)
JowiHue Plug-In Version: 4.0.8.2
deCONZ Version: 2.19.1
Here is the object information LEDVANCE BR30 RGBW light.
Color temperature light
**************************** Object info *****************************
"colorcapabilities": 25,
"ctmax": 666,
"ctmin": 142,
"etag": "5beb3cd542bd120ba9c9773d1247e454",
"hascolor": true,
"lastannounced": null,
"lastseen": "2022-11-23T18:06Z",
"manufacturername": "LEDVANCE",
"modelid": "BR30 RGBW",
"name": "Back Porch 1",
"state": {
"alert": "none",
"bri": 0,
"colormode": "ct",
"ct": 370,
"effect": "none",
"hue": 0,
"on": false,
"reachable": true,
"sat": 254,
"xy": [
0.3805,
0.3769
"swversion": "0x00102201",
"type": "Color temperature light",
"uniqueid": "f0:d1:b8:00:00:06:5b:f1-01"
************************* End Object info ***************************
1. On/Off/Dim
2. Extra
3. CT
"ctmax": 666,
"ctmin": 142,
"hascolor": true,
"state": {
"alert": "none",
"bri": 0,
"colormode": "ct",
"ct": 370,
"effect": "none",
"hue": 0,
"on": false,
"reachable": true,
"sat": 254,
"xy": [
0.3805,
0.3769
