I just bought the Aqare E1 TRV. I have a mode device, which has 3 modes. Off (self explanatory), Full Heat, and Auto. I am controlling it via the setpoints. So should it be on Auto or Full Heat ? If it is on full heat, will it ignore the setpoints ?
What are the Aqara E1 termostat (TRV) modes for ?
I don't 100% know how the valve will respond. Here I am using Eurotronics Spirits. For this device Full Heat set the valve open to 100% for 15 minutes and will then return to Auto. You could look at the Full Heat as a Boost function. Maybe I could better rename it to Boost.
On Auto, the valve (at least on EuroTronics) closes more when the measured temperature is nearing the setpoint or opens more if the temperature is far off setpoint.
Don't know if the Aqara Thermostat is doing the same. Let me know how the thermostat is behaving for you? As I do have some issues here with the Eurotronics thermostat as it looses its connection quite regular, where I need to take the batteries out and back in to restore the communication. Maybe the Aqara is a better choice?
Wim-- Wim
Originally posted by w.vuyk View PostAs I do have some issues here with the Eurotronics thermostat as it looses its connection quite regular, where I need to take the batteries out and back in to restore the communication. Maybe the Aqara is a better choice?
Wim
First impressions with the Aqara are good, but it needs longer to run before I can really make a comment. It sits quite loose on the rad, even after tightening it with pliars. But, it seems to shut down when its reached the temperature. I set it to 19, it seemed to heat to 19, then after the internal temperature sensor was reporting 19, it shut down and the rad stayed cold. But lets see over time.
Regarding the Full heat mode, I left mine at full heat. Its still keeping it cold when set to 19, and heats when I set it to higher.
