Hello.
I have a strange problem.
Using HS4 (4.1.16.0) and the Jowihue plugin 4.0.8.3, connected to a HUE brigde.
The "on/off/dim" value is stuck at "On" when I dim the light to any value.
If I use the DIM slider in the JowiHue plugin, I can see the change in the hue app for IOS, but if I change the DIM level on the hue app (IOS), the slider is not changed in the JowiHue plugin.
Here I have dimmed the light with the JowiHue plugin to approximately 33% as read from the Hue app (IOS), status is only ON in the JowiHue plugin.
Any explanation ot this issue?
Thanks!
Ole
Thanks!
Ole
