I just added 9 Sinope Zigbee thermostats to my HS setup and they all seem to come in fine and I can control them via the device setpoint etc.
When I went to use EasyTrigger in an event to compare Setpoint to the Temperature I noticed none of the JowieHue devices/values are available in EasyTrigger conditions. (I can "Control a device" just fine in the Action section.) Also if I trigger on the "Device Value" they are visible
In case it helps my use case: I want to control a connected relay on my gas fireplace so that it comes on and off with the Sinope thermostat controlling the baseboard heater in the same room. I have done this before multiple times with my zwave thermostats.
Any idea none of the JowieHue devices show up?
Darren
Darren
