Configure device "is light"
    Hello,
    I have 'LIDL' plugs on my Zigbbe network, and I would like to configure them as 'Is Light'.
    When I change the device properties to ''Is Light'' it's OK, and GOOGLE sees it as a lamp. If I restart Homeseer and zigbee, the device is no longer 'Is Light' again.
    Is there the possibility to block it in Is Light'​
    I have checked in my plugin, but this flag is not set by the JowiHue plugin?
    Are you sure you are using the JowiHue plugin for this (as you mention "restart Homeseer and zigbee")?
    If you are using the plugin, then try disabling the plugin and re-enabling the plugin without restarting HomeSeer. Does this change the device too?
    Wim
    -- Wim
      Hello, I just try this test: Select 'IsLight'. Turn Off Plug in JowiHue, Turn ON ==> IsLight is disable
      Matthieu​
        Hello Win,
        so do you have an explanation?
        I do some tests, but each time PlugIn restarts the tick deactivate.​
        Matthieu
          Matthieu,
          I have found the issue here. It will be resolved in the next version.
          Wim
          -- Wim
            Hello, I update the version, but, I have an error when go to setting :
            Error finding plugin in GenPage: Impossible de charger le fichier ou l'assembly 'Newtonsoft.Json, Version=12.0.0.0, Culture=neutral, PublicKeyToken=XXXX' ou une de ses dépendances. La définition trouvée du manifeste de l'assembly ne correspond pas à la référence de l'assembly. (Exception de HRESULT : 0x80131040)
              Matthieu,
              I made an error with updating one file. Can you stop the plugin and download the attache file? Remove the txt extension of the file (rename it to HSPI_JowiHue.exe.config. and place it over the existing file in the installation directory of HS4. Then start the plugin. This should resolve the issue you are seeing.
              Sorry for that!
              Wim
              -- Wim
                Thank's.
                All it'is OK.
                Matthieu
                  I noticed this also.
                  Along with it is the "Recover light settings after being unreachable​".
                  This does not persist through a reboot either.
                  Can you fix that too?
                    I will check on this. I was pointed out by HST on another similar issue. Which HS version are you running at the moment?
                    -- Wim
