I installed Aeotec and Aqara Zigbee buttons. It seems they have been included in the Zigbee network. They show up as devices in Homeseer and Phoscon. If I click on the device in Homeseer it shows up as being clicked in the device page. But it doesn't show up in the log. And if I set up an event based on the click it doesn't seem to work. It seems like I'm 90% there.
Buttons
OK. Does the event turn on the device if you run it manually? Running an event manually bypasses the trigger and conditions. If that works, the action is working and we can focus on the trigger."if I have seen further [than others], it is by standing on the shoulders of giants." --Sir Isaac Newton (1675)
Originally posted by joewilly1 View PostYes, it's enabled.
Wim-- Wim
No it will not matter. It will always show the last button press value. The time updated wil change when you press the same button. Did you check the setting I suggested?-- Wim
Then this should just work. I only can come up with one option, which I think is silly, but if you did not, the event will not trigger automatically:
You did save the trigger right?-- Wim
Originally posted by joewilly1 View PostInteresting...running it manually turned on the device."if I have seen further [than others], it is by standing on the shoulders of giants." --Sir Isaac Newton (1675)
