Unable to create Creativity> Presets (Color)
    I thought that I could add my own color presets by depressing the + under specific Creativity color group e.g. "Whites" but when I depress the + key I only get an empty page, any help/suggestions would be greatly appreciated.
    Computer: CUK Intel NUC7i7BNH
    Op System: Windows10 Pro - Work Station
    HS Version: HS4 Pro Edition 4.2.19.0
    Plug-Ins: AK Weather 4.0.5.25,APCUPSD 3.3.2.3,BLBackup 2.0.63.0,BLEditor 2.0.11.0,BLGData 3.0.55.0,BLOccupied 2.0.28.0,BLShutdown 1.0.6.0,Blue-Iris 3.1.3.33206,Device History 3.2.0.2,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,iRobot 5.22.41.1,JowiHue 4.0.8.7,Nest 3.0.0.34,NetCam Plugin 1.0.0.5,PHLocation2 3.0.0.64,Pushover 4.0.10.0,Random 3.0.0.2,Restart 1.0.0.7,Ring 1.0.0.9,SDJ-Health 3.1.1.3,Sonos 3.1.0.59,Sonos4 4.0.1.12,UltraCID3 3.0.6681.34300,UltraMon3 3.0.6554.33094,UltraNetCam3 3.0.6413.20219,Unifi 4.0.32.0,Zigbee 4.0.11.0,Z-Wave 4.0.3.0, and Jon00 scripts.
    You should be able to add new presets. Will check on this for the next version (today releasing a new version)
    -- Wim
      Just checked here, but for me creating a new preset works... you do see a set of presets when opening the creativity page or don't you?
      -- Wim
        I've attached what I see for your perusal...
        1) Select Creativity
        2) Select add Preset "+" button
        3) Result blank page, have to reload JowiHue plugin
          Yuch, it is working fine here. I am in the proces of publishing the new version. Can you try the new version once it is available (I hope HST will publish it tomorrow). If it is still not working, can you follow these steps to create a verbose trace for me?
          1. Enable verbose tracing and log to file in the settings of the plugin
          2. stop the plugin and start it again
          3. Try to create a new preset with the + button.
          4. Then go to the settings of the plugin again and disable the verbose tracing and Log to file options
          5. Find the file JowiHue.log in the \Logs subdirectory of your HS installation directory.
          6. Send this file to jowihue at ziggo dot nl (or post it as PM frm me)?
          Wim
          -- Wim
            Well, I downloaded v4.0.8.6 I did a "+" on the preset page and it gave me page to enter the particulars but if I expand the Preset group and select "+" I still get a blank page. I stopped/started the Plugin with the same results. Now I get the fol
            Error finding plugin in GenPage: Could not load file or assembly 'Newtonsoft.Json, Version=12.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
            I again did a Plugin stop/start but when I tried to change the settings, I got the above message. I did a full computer restart and was able to create a preset but when I tied the second time I got the blank page.. when I attempted to go to setting it was the above Deja Vu "error message"
            HELP..
              Ok I even deleted the plugin and reinstalled thinking it would fix what ever was missing, but I'm seeing the above error message.. dead in the water!
                Download this file. Stop the plugin and rename this file to HSPI_JowiHue.exe.config, replacing the existing one. I made a mistake in not updating this file for the update. Sorry for that!
                -- Wim
                  Wim, did as instructed, I now have a "INFO:Plugin start is pending" message that hasn't changed, I did a computer restart with the same results when I go to the Plugins I don't have access to JowiHue plugin as it seems to be in limbo. Next!
