Starting this as a new thread, sorry for posting in a old one.
Installing the 4.0.8.6 update, and most of my hue devices is not responding/updating in JowiHue.
Some devices is listed twice, but none of them update status in JowiHue when the hue app control them.
Do I have to remove the plugin and devices and start all over again?
Checked the post at https://forums.homeseer.com/forum/hs...74#post1588474
Those step did not solve the issue.
What I now see, is that group controlling bulbs does not update, but the bulb in the group does.
If I switch the group on, the group control switch from off to on and goes back to off after one second.
The bulb in the groups stays on even if the group switch is off.
And finally, using the dim slider on the group, dim the bulbs to the correct value, but the group is still off as here:
​If I now bring the level up to 100%, the bulb goes from 66% to on, but the group (ID #3128) still say off.
Using the hue app on my iPhone to switch the group on, brings the bulbs in the group on, but the group control is still is off.
And sometimes it help to click 2 times on at the control (ID #3128) for the group, brings the group switch ON, that is strange?
Any suggestion?
Is this related to the plugin or will it help to remove the bridge/reset database?
Thanks!​
Edit: is there a way to downgrade to the version BEFORE 4.0.8.3?
Any suggestion?
Thanks!​
