JowiHue plugin warning / RGB
    I'm using the latest version of the JowiHue plugin (downloaded last week), and it's been working flawlessly. This evening (Feb 12) it's giving me "warnings" about determining the type of device for the RGB option on a Phillips bulb. Here's the log entry with its warning. The plugin / HS4 works perfectly in executing the RGB commands however.
    Any advice??
    Warning: Command cannot be excuted on Down Hall Sandals Photo RGB because the plugin cannot determine the type of device
    2/12/2023 23:16:03
    HomeSeer
    Device Control
    Device: JowiHue Kitchen Down Hall Sandals Photo Down Hall Sandals Photo On/Off/Dim to Dim 100% (100)
    2/12/2023 23:16:03
    HomeSeer
    Device Control
    Device: JowiHue Kitchen Down Hall Sandals Photo Down Hall Sandals Photo RGB to RGB (1)
    No clue yet here. What happens if you restart the plugin?
    -- Wim
      I turned your plug-in off, then on again. Using device control, I sent a few commands to one of the phillips hue bulbs. Here's an excerpt from the log. Sorry about its length, but I want you to see this information:
      Device: JowiHue Living Room Speaker Light (Left) Speaker Left - On/Off/Dim to (value)% (100) by/from: CAPI Control Handler
      2/18/2023 12:32:49
      JowiHue
      Warning
      Warning: Command cannot be excuted on Spkr Left (RGB) because the plugin cannot determine the type of device
      2/18/2023 12:32:49
      HomeSeer
      Device Control
      Device: JowiHue Living Room Speaker Light (Left) Spkr Left (RGB) to RGB (1) by/from: CAPI Control Handler
      2/18/2023 12:32:32
      HomeSeer
      Device Control
      Device: JowiHue Living Room Speaker Light (Left) Speaker Left - On/Off/Dim to On (255) by/from: CAPI Control Handler
      2/18/2023 12:32:03
      JowiHue
      Info
      Started Philips bridge Philips hue
      2/18/2023 12:31:28
      JowiHue
      Info
      HTTPS access enabled on bridge Philips hue
      2/18/2023 12:31:28
      JowiHue
      Info
      Bridge Philips hue refreshing once per 3 minutes
      2/18/2023 12:31:28
      JowiHue
      Info
      Events enabled on Philips hue
      2/18/2023 12:31:28
      JowiHue
      Info
      Philips Hue V2 API initialised
      2/18/2023 12:31:27
      JowiHue
      Info
      starting Philips APIv2
      2/18/2023 12:31:27
      JowiHue
      Info
      Enabling basic ClipAPIV2 on Philips hue
      2/18/2023 12:31:23
      JowiHue
      Info
      2/18/2023 12:31:23
      JowiHue
      Info
      2/18/2023 12:31:22
      JowiHue
      2/18/2023 12:31:22
      JowiHue
      Info
      -------------------------------------Plugin info ---------------------------------------------
