Is this sensor supported - Jeanoko Soil Sensor, APP Connection Plant Monitor Zigbee
    I purchased Jeanoko Soil Sensor, APP Connection Plant Monitor Non Corroding for Zigbee but it seems that it is not working.
    Anyone has any experience with this sensor?
    Sent from my SM-S906U using Tapatalk
      I read here and he was able to successfully integrate it Smarthome. I like the sensor and it may have a prudential with https://smarthomescene.com/reviews/t...gxm-01-review/ How would I check if it is in the zegbee database?
        It seems that it will work with Zigbee2MQTT, can I use it with the combination of Michael MQTT plugin? will it interfere with Jowhue plugin?
          First and foremost, did it add/include successfully with deconz? If the zigbee transceiver/API doesn't successfully recognize it then nothing else will work.
          Since you're posting in the JowiHue forum I'm assuming you're using a ConBee or RaspBee as your transceiver.
          EDIT: Never mind, I did the research, this device is not fully working yet with deconz:
          Issues · dresden-elektronik/deconz-rest-plugin · GitHub
            Thank you, I did some research myself and I did only find one note about adding this sensor. Sorry, next time I will be more precise with what system I have but you were correct.
            Thank you
              They reason I wanted verification of what transceiver you were using is that I didn't want you going down an unfruitful path, like using another plugin to solve the issue when it had to be solved at a more fundamental level.
              these soil sensors look interesting and I'm wondering if the prongs are long enough to be useful in my outside garden. But first we all have to wait until the deconz devs get their act together so the sensors can successfully be added.
                They look interesting to me as well... looking at the images I would estimate the prongs could be 6 cm max, might be a bit short?
                -- Wim
                  The 3 sensors are about 2 1/2 inches while the entire device is 7 1/2. The construction is ok made, expecially the battery department where there are no signs of a positive or negative polarities and both ends look the same, so you don't know how the battery goes. Very bizzarre nowadays to see something like that. The documentarion sucks but I see it all the times. I will try to return it for now and buy when is more of a mature product.
                    Unfortunately I can not return it, how do you go by checking when they release a new update, do you have any notification that you can set that let you know when the team updates those devices?
                      You need to monitor the release page:
                      Releases · dresden-elektronik/deconz-rest-plugin · GitHub
                      If you create an account/sign-in you'll notice in the upper right of the page you can manage notifications.
                        Thank you
