Ikea Vindstyrka air quality - on correct forum this time
    Re-post - I didn't realise I had posted this question on the HS3 Jowihue forum. I am running HS4.
    Hi,
    I purchased an Ikea Vindstyrka with the hope of getting air quality, specifically PM2.5, recorded in Homeseer.
    With a bit of fiddling, I got it to pair with my Conbee II, and it shows up in Phoscon as a device that measures Air quality ('good' etc., rather than the actual numbers), Temperature and Humidity.
    Unfortunately, in HS4 it only shows up as a temperature and humidity device, consistent with those being the only two devices that are shown in the Jowihue configuration.
    On looking at this a bit more, it looks like other platforms running a Conbee II are natively reporting the data for both particulate matter and VOC, in addition to temperature and humidity. I read a report from a Home Assistant user running a Conbee that, when the Ikea Vindstyrka was added it automatically reported the data for VOC, PM2.5, temp and humidity.
    Jowihue recognises the device as an Ikea Vindstyrka, so as I understand it, the additional reporting for both particulate matter and VOC need to be added into Jowihue so that HS sees them.
    If that is correct, can I request that these additional parameters be added into Jowihuhe.
    Thanks.
    Interestingly, after a few days, HS4 has started showing two air quality parameters for the Ikea Vindstyrka,
    Only in terms of 'good or 'excellent' etc. nd I need to work out which is which.
    However, it does however report an additional line which I think is the PM2.5 number - currently showing 107 ppb, which I presume is particles per billion.
    So it is probably only the tVOC units that would be great to see reported. Maybe they'll appear also.....
      I answered on your other post just now... could you post the json and image of the device? I can then check what might be missing.
      Wim
      -- Wim
        Thanks Wim - is this what you were wanting:
        ZHATemperature
        **************************** Object info *****************************
        "config": {
        "offset": 0,
        "on": true,
        "reachable": false
        "ep": 1,
        "etag": "f85618fe6edd8880dab39e06731a9a85",
        "lastannounced": null,
        "lastseen": "2023-06-06T04:59Z",
        "manufacturername": "IKEA of Sweden",
        "modelid": "VINDSTYRKA",
        "name": "VINDSTYRKA Temperature",
        "state": {
        "lastupdated": "2023-06-06T04:58:38.202",
        "temperature": 2000
        "swversion": "1.0.010",
        "type": "ZHATemperature",
        "uniqueid": "34:25:b4:ff:fe:a0:7b:67-01-0402"
        ************************* End Object info ***************************
        ZHAHumidity
        "config": {
        "offset": 0,
        "on": true,
        "reachable": false
        "ep": 1,
        "etag": "b6a5ed28fc25822b2310142f5b0cf595",
        "name": "VINDSTYRKA Humidity",
        "state": {
        "humidity": 6000,
        "lastupdated": "2023-06-06T04:59:47.873"
        "type": "ZHAHumidity",
        "uniqueid": "34:25:b4:ff:fe:a0:7b:67-01-0405"
        ZHAAirQuality
        "config": {
        "on": true,
        "reachable": false
        "ep": 1,
        "name": "VINDSTYRKA AirQuality",
        "state": {
        "airquality": "excellent",
        "lastupdated": "2023-06-06T04:56:00.01",
        "pm2_5": 1
        "type": "ZHAAirQuality",
        "uniqueid": "34:25:b4:ff:fe:a0:7b:67-01-042a"
        ZHAAirQuality
        "config": {
        "on": true,
        "reachable": false
        "ep": 1,
        "state": {
        "airquality": "good",
        "airqualityppb": 102,
        "lastupdated": "2023-06-06T04:55:32.571"
        "uniqueid": "34:25:b4:ff:fe:a0:7b:67-01-fc7e"
          and this....
            hmmm a double ZHAAirquality sensor presented on this one.. that is quite confusing for sure... and indeed the PM2_5 value needs to be added to the plugin. Will work on that. Not sure it will reach the next version as that is already quite a few changes... otherwise it will be in the plugin after that release.
            Wim
            -- Wim
              Thanks Wim.
              Appreciate your support.
