You can download it from your site . with HSPI in front of the last part of the url
mcsMQTT for HS4
Guest
I know it can be downloaded, but then one needs to install it. I expected experienced users to be able to do this, but those not familiar with HS4 alpha/beta process would have a hard time.
In this particular case with the Relays I know I am able to control them with either plugin running on HS4.
Guest
Originally posted by Michael McSharry View PostHST approved the HS4 plugin, but I do not see it published to the updater yet. How did you install it?
The warning are expected since the Statistics devices were created in an earlier plugin version before HS4 considerations were implemented.
The debug from mcsMQTT will contain info about what happens when a relay is attempted to be controlled. General Tab, Enable Debug, Control a Relay, Debug output in \Data\mcsMQTT\mcsMQTT Debug.txt. Post file as a zip.
It was the plugin shop on HS 4 software
Sending debug file from mcsMQTT later today.
I updated to HS4 by uploading the files from HS3, so I still have my HS3 installation
//Jens
The file is 48mb after zipp it, and is to big to send
//Jens
Originally posted by Michael McSharry View PostI suspect you are running a HS3 plugin in HS4. In either case, delete the existing debug file and let a new one be created. The info of interest is current data so the old data does not matter. To delete it you many need to disable the plugin, delete it, enable the plugin.
//JensAttached Files
Your debug contains the following that shows the plugin is responding to the HS control action. The attached contains additional debug on the return status. Unzip the file to replace the one that exists in the bin\mcsMQTT folder. As indicated before I am able to control relays with both plugins so I know the basic functionality exists.
Code:2020-07-08 05:42:05 17811 | SetIOMulti 1608, oCAPI.ControlType=Button, MQTTReceiveRefDictionary.Contains=True 2020-07-08 05:42:05 17816 | CommandControllableDevice 192.168.1.165/RELAY1=Off 2020-07-08 05:42:05 17816 | SetIOMulti 1609, oCAPI.ControlType=Button, MQTTReceiveRefDictionary.Contains=True 2020-07-08 05:42:05 17816 | CommandControllableDevice 192.168.1.165/RELAY2=On 2020-07-08 05:42:05 17888 | SetRelay 0 Off 2020-07-08 05:42:05 17892 | SetRelay 1 On
Originally posted by Michael McSharry View PostYour debug contains the following that shows the plugin is responding to the HS control action. The attached contains additional debug on the return status. Unzip the file to replace the one that exists in the bin\mcsMQTT folder. As indicated before I am able to control relays with both plugins so I know the basic functionality exists.
Your HS log a normal startup for mcsMQTT. There are other plugin messages that have no effect on mcsMQTT. What is of interest is the debug log from mcsMQTT.
Code:2020-07-08 22:03:49 HomeSeer~!~Info~!~Plugin mcsMQTT has connected. IP:127.0.0.1:65411 2020-07-08 22:03:49 HomeSeer~!~Starting Plug-In~!~Initializing plugin mcsMQTT ... 2020-07-08 22:03:49 Legacy-Plugin~!~mcsMQTT~!~Version 5.3.0.4 Registered with Homeseer 2020-07-08 22:03:49 HomeSeer~!~Starting Plug-In~!~Plugin mcsMQTT started successfully in 361 milliseconds 2020-07-08 22:03:49 HomeSeer~!~Starting Plug-In~!~mcsMQTT loaded in 661 milliseconds 2020-07-08 22:03:49 HomeSeer~!~Plug-In~!~Finished initializing plug-in mcsMQTT
We have other discussions on this board about how the Relay IP does not work in many configurations. When I used Wireshark to take I look I saw that the Relay IP had the multicast bit set. This means that routers should not forward the data. Only end points on the same physical LAN will see it.
