MQTT Configuration not returning to original page
    Installed and enabled mcsMQTT 5.5.1.4 on Homeseer 4 V4.1.3.0.
    It appeared fine when I initially configured it yesterday.
    Today I cannot get to the main configuration page. When I go there it appears to be going to the "Chart" tab and I have not configured any charting so it states: No Data to Plot
    Also trying to configure the original GDO SonOff basic device. Guessing each door sensor is "switch 1" and "switch 2". Switch one never changes status.
    Auto mator
    You installed the HS4 version of the plugin. There are still some Github issues outstanding with HS4 that affect mcsMQTT. The one you are experiencing is related to the querystring from the browser that is only cleared on a restart. This means that once something is put in the querystring such as when using most hyperlinks from mcsMQTT it persists until a restart. The chart hyperlink is one such case. To use the HS4 version of the pluign one must manually navigate to the pages.
      Thank you Michael. Just testing it on another box running HS4 which is not production.
      Auto mator
        Updated HS4 to V4.1.5.0 and re-enabled mcsMQTT plugin V5.5.1.4 and all appears well now using Firefox and Chrome.
        I can get to selected mcsMQTT selected tabs with no issues.
        Auto mator
          I get the same good result with 4.1.5.0. I did not see the issue as being resolved in the release notes so it looked like it got fixed as a result of something else being fixed.
