Hi Michael,
Those root devices are making me crazy in HS4. I would really like to have a single root for a device, no matter which topic. When I setup a new device with power, temperature, IP address and Watts, I have 4 root devices... So I went as far as modifying the devices.json to set up my devices with a single root , and it works (but I do not recommend it, as it is quite tricky) and is a lot of work and error prone. And after a restart of mcsMQTT it also recreates some of those root devices (but only the first time??)
So, here is a suggestion: can we specify a root device/root reference BEFORE the association is being created? So it will create the feature as part of the specified root device? That would solve most of my problems. And is also (partly) a workaround for the current issue where HS4 is unable to move a feature to another root device.
Thanks for considering!
