Below is a snip from the log, showing the offending conversion which should be about 73 instead of 7.3.
8/19/2021 9:15:31 PM 24906 | DecodeWMP Received CHN,1:AMBTEMP,227
8/19/2021 9:15:31 PM 24918 | Update Accepted 218 to 7.3 StatusType=2 Payload=7.3 RegExValue=7.3
8/19/2021 9:15:31 PM 24920 | Updating Device from 7.3 PayloadNumeric=True
8/19/2021 9:15:31 PM 24921 | ActOnMessageForTrigger QueueSize=0 ,Topic Daikin/10.0.0.100,Payload {"InsideTemp":"7.3"}
I should confess that I tried out the new IntesisWMP plugin to see what that was about. I didn't have that and mcsMQTT running simultaneously, and the log above is even after I uninstalled the other plugin. As a check, I also loaded the Intesis config tool to see if the somehow another setting was present (it allows for a temp offset of a few degrees F). All of that looks fine. I only mention it here for completeness.
