Hi, I need some help here. I have a Shelly 2.5 configured as a shutter module. This means I have Power1 and Power2 (as separate switches), to switch up and down in an on (open/close) and off (stop) state. I have them configured as separate features in HS4 like this:
So far, so good. But wouldn’t it be better if we would have a single feature with two buttons, Open and Close? Pressing Open once opens the shutter, pressing it again stops the shutter. Same for Close. Tasmota has ShutterStopOpen and ShutterStopClose so it should be possible.
I tried to follow 4.1.28 but I cannot figure it out. I assigned both stat/xxx/Power1 and stat/xxx/Power2 to the same device. Then I try to edit the first topic, but it seems to update the second topic at the same time, so I cannot update the correct Replace fields. Also, I have no clue how to assign the Open and Close buttons to cmnd/xxx/ShutterStopOpen and cmnd/xxx/ShutterStopClose, without sending the feature value.
Thanks!
Thanks!
