Look at the end of post #4 at https://forums.homeseer.com/forum/li...h-wled-devices. There are other descriptions that you can find by searching for updater_override.json for HS4 plugins on the message board in case this one is not clear.
Device with only string payload does not show string anymore since 5.7.0.0
Guest repliedThanks Michael.
Updates that property handle text, VSP, and numbers with and without expressions is at http://mcsSprinklers.com/HSPI_mcsMQTT_5_7_0_7.zip (HS4) and http://mcsSprinklers.com/mcsMQTT_5_7_0_7.zip.
Guest repliedHaha, I am happy to hear this issue was a useful distraction on your flight
As I was testing on the airplane it also has issues. I will upload next when I get internet again. This made the flight seem shorter eith my mind occupied with testing.
Guest repliedwow thanks Michael. Works perfect with 5.7.0.5
I see the issue and attached an update. I'm at airport waiting to board so no time to test.Attached Files
Tags: None
