Plugin Crashing on linux 4.1.8.0
    Just installed the plugin on HS4 ubuntu VM 4.1.8.0 and after enabling it it says running then crashes with the following msh in log:
    The current version is 5.7.0.7 at http://mcsSprinklers.com/HSPI_mcsMQTT_5_7_0_7.zip. Install instructions are at the end of post #4 at https://forums.homeseer.com/forum/li...h-wled-devices. There are other descriptions that you can find by searching for updater_override.json for HS4 plugins on the message board in case this one is not clear.
    Most likely issue is with reference files being wrong version or missing. Installing the latest version will both enable better support and assure all reference files are correct. Also make certain there is no MCSMQTTHS4_2020.dll file in the HS root. It should be in \bin\mcsMQTT. There are other reference files that could be common with other with other plugins. The debug should point that out if it is the case.
    To get more debug information the debug should be enabled. Since you cannot get it started you can enable debug manually by editing \Config\mcsMQTT.ini and assure the line DebugLog="1" is present. The file will be created in \Data\mcsMQTT\mcsMQTT Debug.txt. The file can be zipped and posted.
