Your log shows the homeassistant/sensor/... and homesasistant/light/... topics which give mcsMQTT the information it needs to create HS devices. Device creation occurs when the topic ("state_topic") "zigbee2mqtt/0x14b457fffed111a9" is published. This topic should be published by zigbee2mqtt when it sees a change in the state of the light as it is turned on/off. on/off. This step 10 event of turning the light on/off was not in the log. The log ended 30 seconds after then homeassistant topics.
If one was to look at the Association tab of mcsMQTT I would expect multiple entry for zigbee2mqtt/bridge/state and multiple entries for zigbee2mqtt/bridge/log and zigbee2mqtt/bridge/config to exist. I think you indicated that this did happen.
The things that could prevent mcsMQTT from logging the step 10 "zigbee2mqtt/0x14b457fffed111a9" topic if the topic was actually published is if the mcsMQTT is configured for the topic to be rejected (General tab Reject textbox) reject text"R" column on Association tab). It could also be discarded because the payload is empty or if the topic is a topic that has been setup to be published by mcsMQTT.
Are you not able to run both HASS and HS at the same time or use something like MQTT Explorer to get an independent assessment if zigbee2mqtt does publish "zigbee2mqtt/0x14b457fffed111a9" at step 10?
