I just recently downloaded this plugin. I'm impressed by the amount of work that has definitely went into this. Great job!!
I unfortunately can't connect to an external broker with authentication. This local broker works, as well as an external broker without authentication. Albeit it seems like there is a glitch to even get it to connect without authentication. I have had to either stop the plugin and start it again while removing the IP address or port to be able to have it connect. I can connect to mosquitto broker from other clients without any issues. Perhaps I am doing something incorrectly. I have linked to a thread below where I posted before I realized that it was related to HS3.
mcsMQTT Failing to Authenticate
My Environment setup
HS4 4.1.9.0 on alpine-linux in a docker container
Mono JIT compiler version 6.10.0.104
mcsMQTT Plugin Version 5.9.3.2
I receive the same messages as linked to in the thread above. Is this still an ongoing issue? I couldn't find any other issues related to authentication within the forums here.
mcsMQTT debug log
mosquitto debug log
I'm happy to provide more information to help solve this.
Thanks!
mcsMQTT debug log
mosquitto debug log
Thanks!
