Shelly Dimmer 2 - No Controls in Device Listing
    Good Afternoon,
    I've searched for this with regards to this plugin and if I missed it, please forgive the redundancy.
    Seems the Shelly Dimmer 2 doesn't register properly in HS3 or HS4 (no ON / Off / DIm controls). All of my other Shellies work fine.
    Probably missing something I should have read...
    Thanks!
    First thing is that Shelly Dimmer2 was not advertised by Shelly, but another user observed the same issue and we were able to do the integration of that device so current versions of mcsMQTT will have it. Assuming you are using HS4 that version is at http://mcsSprinklers.com/HSPI_mcsMQTT_5_12_0_8.zip. If you do not know how to use the Updater Override process the look at the bottom of first post on https://forums.homeseer.com/forum/hs...es-to-influxdb
    Since you have already discovered the Dimmer2 then you will need to obsolete it so that mcsMQTT can discover it again. It can be done on the General tab, Inbound Management section, Obsolete row with shellies/xxxx/# where xxx is replaced by the MQTT id of this shelly device. It can also be done from the Association tab where the "O" column checkbox is checked for all the Dimmer2 topics and then the column title clicked to perform the action.
    What needs to happen is that mcsMQTT no longer has a record of this Dimmer2 device so that the next time the topic is seen it will create all the devices.
      Good Afternoon,
      Yes, HS4 (Linux)
      Well that worked well, thank you so much!! I appreciate all your help!
