Hi!
I have a tablet(shows my smarthome dashbard) that can be controlled over MQTT, and the commands and statuses appears in mcqMQTT in HS4 under "inbound selection". If I select a command then a HS4 device is created (both parent and child). But if I´d like to add one more child device to the same parent device this seems impossible. Instead a new parent is created. It is also not possible to edit the "grouping parent ref", any change seem to take no effect.
The first device in the list 1170 created a parent device. Both showed in this list. But when checked the association for device 1172 and statedd that device 1169 was to the parent, device 1169 disappeared from the list. Instead device 1171 appeared as parent for 1172.
Is there a bug around, or me doing something the wrong way?
