I've been playing with mcsmqtt for a day now trying to figure out the plugin. I'm running the latest 5.13.0.0 I've gotten things to kind of work, I can view the status of devices, just can't seem to control anything. I've been using MQTT explorer which has helped a lot. For instance, I have many UPB switches which i can control just fine in the UPB plugin for homeseer. Via MQTT explorer I can view the status, but when I try to change a value, such as dim a light to 50% nothing happens.
My naming convention is like this:
Default Topic Template
Security-DVR/mcsMQTT/$$ROOM:/$$NAME:/STATUS
Default Payload Template
$$VALUE:
Wildcard Non-Plugin Control Template
Security-DVR/mcsMQTT/$$ROOM:/$$NAME:/cmnd
I am not sure what i am doing wrong. In the screenshot of MQTT Explorer I have lights on and I try sending a command to dim it to 50. It does not work.
Also, is it possible to have the same name for Command HS Device on subscribed Topic and on Publish message on Device change using Topic.
In other words, can something like this work too for both "Command HS Device on subscribed Topic" and "Publish message on Device change using Topic"?
This is what i am thinking of but this doesn't seem to work either
This is basically the same thing minus the cmnd and STATUS
Here is an example of a command that does not work
Security-DVR/mcsMQTT/Brian's Bedroom/Ceiling Lights/cmnd
Please let me know what I'm doing wrong. My goal is to eventually get this running with homeassistant, but for now I just want it to work reliably with MQTT Explorer.
$$VALUE:
