Wrong temperature reading..
    Hi,
    I have something strange... I use ESPhome in combination with a sensor which reads (amongst others) Temperature of the surrounding environment. I've setup a MQTT server which is my Homeseer system and your amazing plugin mcsMQTT, I had to add an offset to the temperature sensor, which is working fine, it also transmits the correct data to mcsMQTT, but for some strange reason it shows the old temperature without the offset, while when looking in mqtt explorer it's the correct one...
ID:	1450864Click image for larger version
ID:	1450865Click image for larger version
    So I am pretty puzzled right now... I hope you have some answer to this issue...
    Thanks in advance!!
    Richard
    This could be as simple as a stale MQTT page. mcsMQTT will disconnect a browser after 20 or so minutes if there was no user input on the page.
      The rest seems to be working fine as far as I can see... I just cleared the sensor in HS and reregistered it via de mcsmqqt plugin, it shows the correct values at the moment as far as I can see... we'll see how it goes...
      Thanks!
