I've had this problem before when I was adding a wink relay to Homeseer with mcsMQTT and I ended up having to uninstall, and delete all files related to mcsMQTT and reinstall and reconfigure everything all over again to stop it from using 100% CPU on the homeseer computer.
Now I've just finished installing the wink hub and configuring it as well as 2 sonoff S31 plugs and the homeseer server is using 100% CPU and when i break down the process it shows HSPI_MCSMQTT is using 90-98% CPU constantly.
Any suggestions on debugging this and what would be causing it?
