Broadlink makes a family of products at a reasonable price that can learn, import, and transmit IR codes from WiFi commands. The Pro models can also do the same for RF at various frequencies.
I have added the Broadlink family of devices for non-cloud operation in version 5.15.0.0 of mcsMQTT. There are a variety of software integrations available that have become stale as new Broadlink products have been introduced. For my development testing I have been using the Broadlink RM4 Pro which is the current production for both IR and RF. Since I built upon the work of others with earlier generation Broadlink devices I expect backward compatibility. If not then we can figure it out. mcsMQTT supports Broadlink setup, IR learning, RF learning, and importing of known IR and RF codes. More is contained in the manual that is included with the download.
The Broadlink device establishes a connection with a server. In the mcsMQTT implementation the server is mcsMQTT. This means that those that desire cloud control using the Broadlink App rather than local control should not be using this integration.
mcsMQTT can connect to the AP that is advertised during the Broadlink setup process. This will establish the link between the mcsMQTT server and the Broadlink device client. An application is also included that will do only the part of the Broadlink setup that connects it with a local network.
I have been away with only a IR remote for testing. This means that RF has not yet been tested, but I do not expect any difficulty since the same methodology is used. I have also only had access to a Windows computer that has WiFi. I confirmed that the updated plugin runs on Linux, but I cannot evaluate the Linux operation as the Linux resource I have does not have WiFi to do the initial connection to the Broadlink AP. Next week for RF and Linux testing.
For the HS user, what is created is a HS device with an IR and RF feature. It will provide a dropdown selector to show each of the IR and RF codes that have been learned or imported from other sources. Making a selection will result in the Broadlink device transmitting the selected code. Control can be from HS, HS Events, or MQTT messages.
mcsMQTT 5.15.0.0
http://mcsSprinklers.com/mcsMQTT_5_15_0_0.zip
http://mcsSprinklers.com/HSPI_mcsMQTT_5_15_0_0.zip
Install instructions at the bottom of first post at https://forums.homeseer.com/forum/hs...es-to-influxdb
mcsMQTT 5.15.0.0
