The documentation states
"4.1.32 How to record changes to HS Log When a device is controlled from the HS UI then a “Device Control” action is put in the HS Log. If a similar logging is desired when the device is updated based upon MQTT payloads then two setup actions are needed. First is on the General tab (Figure 36) using the Pub-Sub Message History checkbox to Log changes"
But man I am just not seeing the Pub-Sub Message History checkbox on the General tab?
I have version 5.14.3.6 installed.
