Found this post by DigiBlur....
Wyze Outdoor Plug with Tasmota posted on March 7, 2021
I preordered it from Amazon and got it this week.
WYZE WLPPO1-1 Outdoor Smart Plug, White for $15.98
DIY firmware upgrade to ITead S31 Smart Socket switch
Noticed that the Wyze Plug is on the Tasmota template DB.
Found a reference to the wyze_plug_flasher which is OTA.
I have never used an Wyze device. After reading not totally understanding the description / step by step ...mostly this piece...
py wyze_updater.py list
which I assume means that I have to create an account on wyze cloud for this to work.
That said taking it apart and doing the update manually.
First thing I noticed is that the 5 screws that hold the case together are Triwing tamper resistant screws. I was able to get three of the five screws out with a small screwdriver and ordered an el cheap tri-wing driver set from Amazon.
Will take pictures of the inside when this device is apart and continue this post.
Took the case apart today. The cover is not glued and screwed on. The cover came right off. There are 5 screws inside holding the board to one side. I removed all of the screws and pulled the board out to take pictures. JTAG port is labeled and has solder pads. Same with 3.3VDC. Soldering little wires to the pads to JTAG the device to Tasmota. Really a tad easier that JTAGing the Magic home controller.
Updated my soldering station tips and purchased 28 guage multiple color wire. I was using 26 guage and ran out.
I purchased this on Amazon:
Fermerry 28 AWG Stranded Wire Silicone Cables Hook up Wire Kit 6 Colors 5Ft Each 28 Gauge Electrical Wire (5FT 6 Colors, 28AWG)
I only had white wire left on my old 26 guage spools.
I know this is temporay but will probably leave the wires inside.
22 of March, 2021
Soldered the 28 guage silicon wires to the WiFi pads on the board. (3.3VDC, ground X2, RX, TX and boot). I have never used this guage of wire with a silicon shelding. It is very flexible but a bit too skinny. It was easy to strip the 28 guage silicon coated wires.
Will power board with 3.3VDC and update it to Tasmota soon.
31st of March, 2021
Updated to tasmota32.bin today reading this blog post. Needs more power than what comes from USB stick so you have to power it via your 120VAC plug to configure Tasmota.
How to Flash the Wyze Outdoor Plug - ESPHome Local Control No Cloud
Features of the WYZE Outdoor plug
And used this Tasmota template:
Wyze Plug Outdoor Plug
It is not soup yet on the completed Tasmota development. I am impressed with the device.
- Long-range WiFi lets you plug in nearly anywhere. Up to 300' WiFi range. Confidently control outlets around your home with Wyze Plug Outdoor's extended WiFi range (300 ft. in open space). Set energy consumption alerts and see historical energy usage in the Wyze app.
- Made for the outdoors: IP64 Weather Resistant. Safely plug into areas that are exposed to rain, dust, dirt, and snow.
- Independent control of both outlets at any given time- two outlets in one. Turn off your outdoor lights but leave your inflatable snowman standing strong.
22 of March, 2021
31st of March, 2021
- ESP32 for Bluetooth scanning!
- Higher Gain antenna than a normal ESP module PCB antenna
- LUX Sensor
- Power Monitoring (Both relays combined, single channel)
- Dual Relays
- Dual Status LEDs
- IP64 Weather proofing
- 15 Amp capacity
