I'm looking to embark on a project where I will be flashing some Tuya-flavored RGBW bulbs, using Tasmota firmware, so that they can be locally controlled.
I've done some research and it sounds like MQTT is the method of controlling them following the flash, but am a little green when it comes to MQTT, and have never used the "homeassistant" auto discover feature baked into the mctMQTT HS4 plugin.
This is the guide I will be following for the most part, which talks about a "template" for use and some specific MQTT configurations, but unfortunately which seems to maybe be specific to the actual Home Assistant platform. I did some additional research and found older mcsMQTT thread postings that seem to indicate this plugin will work very much the same way on HS4, but am a little lost as far as how exactly to integrate the new bulb with mcsMQTT on HS4.
Do I start by using something like MQTT Explorer to discover the available topics, and then try and set this up from scratch, or is there a way to get the plugin to try and do this automatically somehow?
I don't actually have a flashed bulb in my hands yet to play with, which is part of my problem. I would like to be somewhat confident it might actually work before I do, so was hoping someone could nudge me in the right direction, where I might go after I do actually have a flashed bulb, that would be much appreciated.
https://danielbkr.net/flashing-bulbs-ota/
