I bought a Shelly button to have a play with.
I have it set up and can see the button as a Device in HS - all's well so far.
I can use the button in an event but - the HS device retains the last setting. If I use the same setting again (S for a short push) the event doesn't fire as the device is already set to S.
Suggestions for what I should be doing welcome :-)
