no statistics tab any more
    I installed latest version 5.15.7.0 on my RPi4 and now the statistics tab is missing in the mcsMQTT page.
    Furthermore it is not possible to go to the next page of associations although 65 are selected. An empty page is shown but the counter is set to 20.
    Statistics are now encapsulated as topics MQTT/Statistics/+ so are viewable on the Association tab. They can be individually selected for association with HS device and history data can be collected.
    For the paging I suggest looking into HS and debug logs to looks for any errors that may be reported. Additional information may be able to be gleaned by typing in a number in the text box rather than using Next button.
      I find it hard to find, these encapsulated topics...
      Here you see the page I get:
      If I choose 'Show All Associated Only' then 65 associations are selected. I only see these 8:
      If I select next or as you suggested type in a number, then also no associations are shown.
      If I set debug to on in the general tab then I see no messages in the Debug file.
      Any idea what is going on?
      -- Cor --
        If you want to view statistics then in the "Filter Table by Category" select the bottom checkbox to include plugin devices. In the "Filter by MQTT Topic and JSON Payload Key" section select MQTT for T1. Select "Show Selected Associations". If you want one or more of the statistics viewable in HS then use the "A" column checkbox.
