I just installed the plugin and am a bit confused about a couple of things. It may well be pilot error, but I figured I would post. For now, the only thing I want to use the plugin for is to send data to InfluxDB for use with Grafana.
From what I've read in forum posts, I should just be able to go to the Associations page, check the "Include Non-Plugin HS Devices" checkbox, and then check the "i" column for the devices I want to send.
However - when I do that, I'm not seeing all my HS devices. The first one I see is a much higher ref than the actual first device. The same is true for the other end. I have a number of devices with refs that are higher than the last one I see in the list.
I should add that I'm not setting any filters on the Associations page. Am I doing something wrong?
