If I send both the Value and String in a JSON packet, is there a way to parse them out into the HS device. Seems likely, I just can't see where to do it.
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
