Switching out a bunch of Arduino boards over to Tasmota and mcsMQTT. Two boards (Arduino) control relays and I'd like to switch them out. Doing a test board, I get the Tasmota board set up with relays to appear in HS4. I can toggle the relays using the Tasmota GUI but in HS4 I stumped as to how do I toggle the relay on and off. I have the "ON" "OFF" buttons but obviously they are not functional. Somehow I'd have to send a payload back to the the board via HS4, but how is the question.
Esp8266, Tasmota, Relays?
How did you setup to get the buttons in HS4? Were they created by mcsMQTT Association checkbox for the topic?
The process using mcsMQTT is to observe the relay topic on the Association tab, use the Associate checkbox to create a HS Device and Feature. Click on the Ref button that was just created and confirm Button is the control/status UI setting and then enter the Tasmota topic in the Pub Topic textbox. Stock tasmota will use cmnd prefix for pub topic rather than the the stat or tele prefix used in the sub topic.
Typically Tasmota transmits tele periodically and stat when the relay changes. The tele will be a JSON payload and stat will be just on or off. This will create two rows in the mcsMQTT Association table. To update on receipt of either topic then type the ref number that was created during the association into the Ref textbox on the second row.
