HI! I am trying to setup a dimmer device that can be controlled by Google Home (voice controlled). I subscribed to the STATE
IMMER topic, which gives me a slider from 0-100. This can be controlled successfully from Google Home. However, On/Off is more challenging.
I manually (with some scripting help) created an On and Off button, values Appvalley 0 and 100. But this sets the Dimmer to the lowest and highest values, not actually on and off. So when I turn off the light by voice, it isn't easy to turn on again by the physical button as I need to turn it up all the way. When I turn the lights on, it is being set at the highest level.Tweakbox
I need to send a cmnd/xyz/power on/off for on and off. And a cmnd/xyz/dimmer for values 0-100. Al in the same feature, so Google Home understands and can turn off the light while retaining the last level, and turn on the device at that level again.
Any good ideas? I don't see how (with the use of LABEL and VALUE) I can do a proper replacement to construct the correct MQTT command.
