Updater packages for mcsMQTT version 5.19.0.2 are at
HS3: http://mcsSprinklers.com/mcsMQTT_5_19_0_2.zip
HS4: http://mcsSprinklers.com/HSPI_mcsMQTT_5_19_0_2.zip
For those that do not know the Updater Override process there is a description in the first post at Direct Storage from HS Devices to InfluxDB - HomeSeer Message Board
This version adds protocols for command/response POST, UDP as client and/or server, and Webhook/WebSocket for listen-only connections. Previously GET, TCP and MQTT were the only supported protocols. While this is an incremental addition, it also has split the TCP page into a Local and a Cloud page. It is mainly a structural change and not a logic change so I do not expect issues, but it would be nice to have feedback confirming this hypothesis before actually pulling the trigger and releasing it via HS Updater.
The Update package does contain the updated mcsMQTT.pdf documentation, but it is also available independently at http://mcsSprinklers.com/mcsMQTT.pdf.
