Quickly finding YoLink unique assigned device/sensor serial numbers
    Is there is a quick way to "only or just find" all instances of a YoLink unique device/sensor serial number?
    Adding several YoLink devices/sensors for HomeSeer expands the mcsMQTT "database" dramatically and manually searching for report/response topics becomes somewhat very time consuming. Please note: I am a newbie with mcsMQTT.
    A YoLink device is recognized by mcaMQTT based upon the QR code that is entered on the Cloud page. YoLink tab. YoLink Server reports back a device identifier for the QR code and that is how mcsMQTT shows the device on the MQTT Page, Association tab. The T1 filter on this tab should be selected to by YoLink and other filters used to narrow down the specific device. T2 filter will be the unique ID for the device assigned by YoLink Server. If it is not obvious to you which unique ID is associated with which QR code then look in the HS subfolder \Config\mcsMQTT\mcsMQTT.ini in the section [YOLINK] and this will contains the QR code to Unique ID relationship of your devices. You can rename the HS devices after they are created to be more recognizable. On each YoLink physical device an abbreviated QR code is printed and this can be used to identify the full QR code.
