So I have BLEMQTT running on a Raspberry pi and it is reporting to my MQTT broker on a server in my network . MCSMQTT (HS4- latest version) points to the same broker and I added the beacons. I set the beacons to store zero when in range. I set the timeout to 90 (the pic has it at ten but I have updated it)
The issue is the values of the beacons in range keep changing. I just have an event that fires endlessly when the value changes, and in the GUI-- I see the image flip flop between green (value zero), and then the back to the black gear. This seems to happen whenever I see that particular beacon report when I look at mosqutio_sub.
Any ideas?
Any ideas?
